Comment raccorder des tuyaux qui sortent du mur ?
Par dolus
avatar - dolus
Message(s) : 11
15/06/2020 à 15h51
15/06/2020 à 15h51
Bonjour, je suis mauvais, ou novice c'est au choix.
J'ai voulu changer mon mitigeur de douche mais le tuyau cuivre a explosé. Le plombier m'a résoudre à l'identique, avec les sortie apparentes, pas à flanc de mur. Résultat, les raccords de ma nouvelle robinetterie sont bien trop grands pour que la rosace vienne contre le mur... que puis je faire pour un truc propre ? Merci de votre aide !
Par dolus
avatar - dolus
Message(s) : 11
15/06/2020 à 16h00
15/06/2020 à 16h00
Je m'autorise une réponse à ma propre question: avec un raccord 15/21 male/male droit ?
avatar - MollyEskam
15/06/2020 à 16h35
15/06/2020 à 16h35
Fixing a pipe inside a wall is no easy task, so it’s a lot better to let a professional plumber deal with this. But if you feel confident you can do it yourself, just follow these instructions. Cut out sections of the damaged drywall with a saw. Once you are completely sure where the damage is located, cut the wall in order to have access. Wrap a sheet around the pipe and move around until it gets wet. If you don’t have the luck to see the breakage with your own eyes, you’ll need to find it with a sheet of cloth. You may have to repeat this a few times until you pinpoint the exact place of the breakage. Place a container under the broken pipe. The plumbing repair will be messy, so the container should catch anything that spills from the pipe you’re about to work on. Cut the pipe below the leak. You need to use a pipe cutter tool for this. Screw the tool tightly and rotate until the pipe is cut through. Dry the pipe. You can’t work if it’s wet. Cut above the leak with a pipe cutter again. Clean the pipe. This includes both the inside and outside. The inside might hold more ice, so make sure it’s clear from any obstructions. Mount a copper repair sleeve. Use a blowtorch to heat the bottom end of the repair sleeve. Allow the solder to melt and fill the joint. After it cools in about 10 minutes, do the same for the upper end. Wear safety goggles and gloves when doing this. Check for leaks after you’re done. Patch the wall.
15/06/2020 à 17h55
15/06/2020 à 17h55
..Fixing a pipe inside a wall is no easy task, so it’s a lot better to let a professional plumber deal with this. But if you feel confident you can do it yourself, just follow these instructions...
Hello !
It is a French forum for which the charter requires to speak in French ..!
Please translate the message!
Note :
Here there is nothing to sell, all suggestions are FREE !! : tpr:
Hello !
C'est un forum Français pour lequel la charte impose de s'exprimer en Français..!
Merci de bien vouloir traduire le message !
Remarque :
Ici il n'y a rien à vendre, toutes les suggestions sont GRATUITES !! Ca tourne pas rond là-dedans
avatar - Céline_BDD
Message(s) : 1680
17/06/2020 à 12h12
17/06/2020 à 12h12
Hello,
J'ai traduit le message (non je rigole, j'ai fait un coup de deepl)
Fixer un tuyau à l'intérieur d'un mur n'est pas une tâche facile, il est donc préférable de laisser un plombier professionnel s'en occuper. Mais si vous êtes sûr de pouvoir le faire vous-même, il vous suffit de suivre ces instructions.
Découpez à la scie des sections de la cloison sèche endommagée. Une fois que vous êtes complètement sûr de l'endroit où se trouvent les dégâts, coupez le mur pour y avoir accès.
Enroulez un drap autour du tuyau et déplacez-vous jusqu'à ce qu'il soit mouillé. Si vous n'avez pas la chance de voir la cassure de vos propres yeux, vous devrez la retrouver avec une feuille de tissu. Vous devrez peut-être répéter cette opération plusieurs fois jusqu'à ce que vous ayez localisé l'endroit exact de la rupture.
Placez un récipient sous le tuyau cassé. La réparation de la plomberie sera salissante, le conteneur devrait donc pouvoir recueillir tout ce qui se répand du tuyau sur lequel vous allez travailler.
Coupez le tuyau en dessous de la fuite. Pour cela, vous devez utiliser un outil de coupe de tube. Visser l'outil et tourner jusqu'à ce que le tuyau soit coupé.
Séchez le tuyau. On ne peut pas travailler si c'est mouillé.
Coupez à nouveau au-dessus de la fuite avec un coupe-tube.
Nettoyez le tuyau. Cela comprend l'intérieur et l'extérieur. L'intérieur peut contenir plus de glace, alors assurez-vous qu'il est dégagé de toute obstruction.
Montez un manchon de réparation en cuivre. Utilisez un chalumeau pour chauffer l'extrémité inférieure du manchon de réparation. Laissez la soudure fondre et remplir le joint. Après avoir refroidi en 10 minutes environ, faites la même chose pour l'extrémité supérieure. Portez des lunettes de sécurité et des gants pour ce faire. Vérifiez les fuites après avoir terminé.
Recouvrez le mur.
Bricolo novice
Visiteurs non identifiés : 51
